Yesterday's Tractor Co. New Parts for Old Tractors
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Servicing 188 injection system
[Return to Forum]
gusbratz
08-14-2012 04:24:01
205.132.74.4
I have an old case 530 Ag tractor with a 188 diesel (early 70’s); I traded a farmall cub for it. It was in pretty rough shape but I got some tires that hold air and a battery and re-wired it. Fabed up some 3 point hitch parts to get that working again, gave it a brush paint job and have been using it here and there. Now I plan to start using it on a regular basis and have decided I can’t keep putting up with way it runs. It starts right up and pulls hard (really hard compared to my 530 backhoe with 188 diesel) but smokes diesel smoke all the time, especially under load. The injector lines leak where they go into the injectors, especially #4. It actually squirts out. Makes a big mess all over the engine. So yesterday I drained the tank and pulled the filters and injector lines. I am going to try to clean and set the pressure on the injectors with a little homemade pump set up. I successfully did this on some IH midget injectors that took shims. These look easier because they have a pressure adjusting screw on top. I plan on putting some new seals into the injector pump with hopes that it will run cleaner. I am wondering if somebody “turned up the pump” on it because of the way it runs rich. This will be my first time working on an injector pump. But I have a lot of them that need serviced so I want to learn to do it for future use. So my question is Does anyone have a good way to fix the leaky fittings where the lines meet the injectors? Does any one have any tips on how to service these components? I am placing an order to us diesel on Friday, should I buy any special tools? Pump is a DBGFCC 431-27A
[Reply]   [No Email]
gusbratz
09-08-2012 20:38:48
205.132.74.4
Re: Servicing 188 injection system in reply to gusbratz, 08-14-2012 04:24:01
this was my solution to the bad return line fittings, i twisted the whole header till it was pointing up and then cut the flares off. then i put 1/8" npt-3/16 hose barbs in the injectors and popped a hose in between them. hopefully it stands up to the exaust heat.
  [Reply]  [No Email]
gusbratz
09-03-2012 08:23:30
75.218.157.9
picked up 4 new injector nozzles and set the pressure at 2250, rebuilt the pump and put it all together, replaced the fuel filters and primed the supply side of the system. had my freind pull me down the road with his truck for about 400 yards it started up. it was smokeing like a choo choo train and the return header is leaking all over the engine so i pulled it right back into the garage. the return header is some kind of weird fittings with little rubber grommets in them that are all dry and hard. i made some new ones with a hole punch and some 1/4" sheet rubber and then one stripped out. then i tried to remover the fitting from the injector and it twisted off. i don't know what i am going to do with it now. drill out the injector and try to tap it with 1/8" pipe tap then maybe rig something into it that i can braze to the return header. so in summery pretty much everything is worse than when i started. fittings are twisted off, tractor won't start, fuel system leaks everywhere and i am feeling pretty disgusted with the whole mess.
  [Reply]  [No Email]
320B
09-03-2012 17:25:19
70.29.89.242
Re: Servicing 188 injection system in reply to gusbratz, 09-03-2012 08:23:30
That sucks,I hate when things I do go that way.I was really hoping you where going to have step by step pictorial for the rest of us.I have never worked on injection systems before because I'm kind of scared of things I don't really understand.Good luck and I hope you get it fixed.
  [Reply]  [No Email]
gusbratz
08-19-2012 12:49:26
75.214.6.50
does anyone know where i can get a CAV injector nozzle BDLL169S6402 one of them won't clear up and pop nice.
  [Reply]  [No Email]
gusbratz
08-17-2012 02:34:20
75.218.46.255
here is what i am ordering from us diesel today, if anybody has any advice on things i should add let me know.
24371 kit in stock $ 14.06 each
29111 EID in stock $ 49.83
16320 pilot tube in stock $ 8.55
20849 met valve in stock $ 18.03
24992 cam screw tool 1 week $ 18.66
11318 transfer pump blade kit in stock $ 6.33
16753 transfer liner in stock $ 11.10
  [Reply]  [No Email]
gusbratz
08-15-2012 05:06:40
205.132.74.4
found this on the interweb, how the pump works
http://files.asme.org/asmeorg/Communities/History/Landmarks/10001.pdf
found this on red power,
DB, D is series, and the B is indicative of .920" diameter rotor with delivery valve bore. G is mechanical governor, F is flange mount, V is vertical (4020), C is clockwise rotation, CC is counterclockwise(viewed from drive end), 4 is # of outlets(feeding cylinders), 31 is .310" plunger diameter. there are .250,.270,.290,.310,.330,.350,.370,.390,.450. 5 is specification
  [Reply]  [No Email]
gusbratz
09-08-2012 20:35:21
205.132.74.4
Re: Servicing 188 injection system in reply to gusbratz, 08-15-2012 05:06:40
tore it back apart today and that shaft was off one gear tooth, of course the 1 thing i screwed up was the thing that EVERYTHING had to come apart to get to lol. oh well next one will go better.
  [Reply]  [No Email]
gusbratz
09-08-2012 20:36:06
205.132.74.4
Re: Servicing 188 injection system in reply to gusbratz, 09-08-2012 20:35:21
heres everyting all ripped apart
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
