Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 1896 remote problems
[Return to Forum]
Thad
08-02-2012 14:08:32
166.102.180.62
I have a 1896 that a guy brought me with one set of remotes weak. The other set is fine. I noticed several orings and such in the parts breakdown. I havent messed with to many of the remotes and dont want to take it apart unless i have to. So anyone had a problem like this before and what fixed it? Or have any good advice on what i need to do. Thanks Thad
[Reply]   [No Email]
case trader
08-02-2012 17:29:04
67.142.162.20
Re: 1896 remote problems in reply to Thad, 08-02-2012 14:08:32
hey Thad you might look at the back side facing the trans there is a flat screw driver slot remove this and see if there is a small o-ring gone, this should be a nylon on the 96 series o-ring on the 90 series but it might have been changed,i have more trouble here than anything,i guess the other remotes test ok?
  [Reply]  [No Email]
Thad
08-02-2012 17:45:17
207.119.213.176
Re: 1896 remote problems in reply to case trader, 08-02-2012 17:29:04
I pulled them off and indeed one screw has a tan colored oring that is cut. The older post refers to that same area. Thanks for the tips guys. Thad
  [Reply]  [No Email]
JGarner
08-02-2012 21:08:28
70.139.176.83
Re: 1896 remote problems in reply to Thad, 08-02-2012 17:45:17
The tan color would signify that the o-ring material is probably not nitrile (Buna), neoprene or Viton they are usually black. The only tan rings I have seen were epychlorhydrin (probably not spelled right). My guess there is something in the TCH that could adversely effect nitrile, but Viton should work in that fluid. 'Bout the only thing Viton doesn't like is water, especially hot water and some amine based corrosion inhibitors but you usually don't see these in commercial hydraulic fluids. Also, Viton will take temps to about 300-350F.
Jim
  [Reply]  [No Email]
mEl
08-03-2012 04:26:00
108.10.129.170
Re: 1896 remote problems in reply to JGarner, 08-02-2012 21:08:28
Quoting Removed, click Modern View to see There are also Orings under the screw plugs that must have the bottom spool caps removed to access them, might as well do them all while the valve is on the bench. Best to get OEM Case rings instead of generic IMHO.
mEl
  [Reply]  [No Email]
Jeremy McNary
08-02-2012 14:20:15
216.249.230.220
Hi Thad, there was a posting on a similar problem a week or two ago, search for 2090/2390 hydraulics in search and check out the replies to IHmanky's post I think you should get a good idea of what you need from it.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
