(quoted from post at 11:40:56 08/02/12) That won't make much difference on power. How about putting it on a diet and go to a lighter class? That would cost less and be easier than what you are talking about.
(quoted from post at 11:11:03 08/02/12) Don't know about power steering, but the fan uses 5-15 hp depending on what rpm's your running. You could gain a bit by matching all the manifold joints so they have no ridges where they match up, especially at the head. Depending on how bad they are you could get 10 hp there. Also you could remove the air cleaner and add a bell at the intake. If you look at any race engine they most always have a bell on the intake to help eliminate the turbulance which restricts flow. These things all make more difference at higher rpms than at stock rpms.
(quoted from post at 14:01:29 08/02/12) Put a 284 cid out of a 830 in it. Several around and call it a 830. No difference in tractors!
(quoted from post at 16:26:50 08/02/12) 1 Strech the hood and put a 504 in there.
2 Look for a 336 out of an 870
3 Make your own 336 out of a 284 . Use 504 case sleeves and pistons from a 504 Minnie. Use intake from a 400 diesel along with a carb from a 4020 or some other gutless gas hog. Have someone file on the cam. (IH grind) you can get 100 plus hp pretty easy.
4 Run 16.9 38s if allowed.
(quoted from post at 19:55:24 08/02/12) What classes and what gear you pulling in. I pulled my 801 in 8500lb in 2nd and 9500 in 1st with 18.4-38's on it. All the power I needed. Also same with my 702B. My 812 gaser has the power but not the traction.
caseman-d
(quoted from post at 19:24:42 08/02/12) You should be able to make that tractor pull at 6000. We pull one at 5500 with 400 cast centers and no hydraulic housing. You are right these tractors pull better in heavier classes. It is easier to build a 284 to 336 than find a 301 gas. If your rules will allow you may want to think about a 930 gas built to a 504 as the weight would not be a lot more. Look for a late 930 that has a 401 make it 504 and use 830 heads. The only machining would be on the bores on the block, 504 case sleeves you can by used along with the Minnie pistons. Then you can pull up to 12000 in mph classes. Look back a page or two at the ugly Case with the six cylinder direct injection. We also have the big 400 gas and diesel Case-o-matics. Use you imagination
(quoted from post at 17:00:12 08/03/12) the things that make power are cubic inches and enough air flow with enough of a carb feed it along with some compression and good ignition the rest is just chicken feed
b:bf45fe1f40](quoted from post at 21:46:37 08/07/12)
1. get your max rpm by the rules
2. put a cool can on your fuel line
3. gut your air cleaner leave the 1/4 of the steel mesh fill with dry ice. cold air and fuel is your friend.
4. get some lp heads mill them down.
5. some how ice down your fuel tank between rounds.
6. go to sae 30 motor oil in trans. loose power in thick gear lube . especialy wth the late fall/winter pulls
