Yesterday's Tractor Co. Affordable Parts, Just in Time
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 70 series gear ratios
[Return to Forum]
lucky 13 puller
07-30-2012 20:30:22
207.177.65.31
so I have discovered i really need a little taller gear on dad's 1370 hot farm/10,500 open tractor. my question is there a way to make 3-3 higher or 4-1 lower? we can get out in 4-1 with the shorter tires we have but it wheel hops more times than not. in 3-3 with taller tires still run out of wheel/ground speed. someone told me 1570s have a higher ring and pinion gear? any help would be great!
[Reply]   [No Email]
lucky 13 puller
08-10-2012 17:17:47
207.177.65.31
 Re: 70 series gear ratios in reply to lucky 13 puller, 07-30-2012 20:30:22
i appreciate all your advice mel and when we build our next tractor that is the transmisson we will be using. I do realize the tranmissions in an 11 and 13 are completely diferent. we are not at the top levels of pulling. we are mostly pulling 3000 rpm classes and changing govener springs and bigger turbo for some local fair open pulls. i'm guessing 475-525hp we built what we had laying around in the shed and we run mid pack. i really think we have more horse than most we pull against and just need more gear. we don't have the resorses to tear apart a bunch of junkyard tractors to find out nothin will work. just wondering if anyone had been there willing to help thank you for your time
[Reply]  [No Email]
lucky 13 puller
08-09-2012 20:05:27
207.177.65.31
so one last thought then i'm outta ideas, an 1175 ring gear has to be aprox %30 faster than a 13 because of the planitarys right?? anyone know if that will fit?? anyone have an idea if my guess is right on gearing?? if anyone has some info it would be really appreciated! would be cool to spank the red and green show with a case and i have the horsepower!! please help!!
[Reply]  [No Email]
mEl
08-10-2012 04:21:47
71.245.58.204
 Re: 70 series gear ratios in reply to lucky 13 puller, 08-09-2012 20:05:27
Anyone doing serious competetion at the higher levels have long since quit trying to make the powershift hold and have gone to the small transmission as used in the 4-7- thru the 830 transmissions, they are lighter, plenty durable even at the very high HP's we are seeing here in Pa.
I am personal friends with Chris Hoyt and Art Woolever whose 930 was just pictured on the tractor pulling forum and am very familiar with their tractors, anyone around the pulling scene who knows these two tractors will tell you they represent Case well.
There is very little that will interchange between the 1175 and the 13. If anyone knows anything about Case they know that they are totally different design transmissions.
Gear ratio differences? no one is studying that as not many are using that setup for the top levels of competetion. I will say that there are people interchanging range gears on the small transmission which change gear ratios to above present 8th ratio.
The small transmission is lighter and stronger in power handling capabilities for all out performance, The way the pullers that are after serious HP have to load the engine against the clutch to get a lot of boost up on the line creates so much slippage in C2 clutch that the plates are destroyed in one run. This happens at HP levels over 6-700, these are all out competetion machines and uses ideas that most would not consider
We are running totally multi disc slipper clutches with no springs in the pressure plate, just weighted fingers that depend on RPM to create the necessary PSI to lock the clutch.
The two above mentioned Case can be viewed on Youtube if anyone is interested.
[Reply]  [No Email]
lucky 13 puller
08-04-2012 12:57:00
207.177.65.31
no luck there, lots of assembley diagrams, no luck on tractordata either. the advertised speed for both tractors the same in 3-3 but diffferent for other gears, running out of ideas
[Reply]  [No Email]
lucky 13 puller
08-02-2012 18:55:37
207.177.65.31
ok i'll give that a shot, thanks
[Reply]  [No Email]
lucky 13 puller
08-02-2012 06:35:41
207.177.65.31
no one one here knows if the ring gears in a 1570 are taller than a 1370?
[Reply]  [No Email]
j huike
08-02-2012 06:55:00
50.102.69.216
 Re: 70 series gear ratios in reply to lucky 13 puller, 08-02-2012 06:35:41
MUST BE TOO COMPLICATED ??they dont know why the pto disengaes in a hardpull either ?,, go to the530 throttle linkaeproblemthere is a link you can o to that will ive you info for every tractor built ,, also clik on archives and type in keywords ,, lot of ood info there that has been in cyberprint for 15 yrs ,,
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
