| Case Tractors Discussion Forum |
Topic: 970
[Return to Forum]
| Author |
[Modern View]
| jim sunnus
07-28-2012 03:58:01
64.180.192.74
Hello. Our 970 has a problem in that when the trans oil is warm or hot ,the inching pedal engagement is very extreme.When it is cold, the tractor acts like any standard transmission in that you can engage slowly & smoothly. I took some pressure readings & got lube-62 @idle & 75 @ 2000rpm,the readings @c1,2,3&4 were all 185 @ idle & 200 @ 2000rpm. If you push the pedal past what would be called free travel on a clutch,C1 drops a few psi & oil flow can be heard through the valve. If anyone can direct me to where I can look to remedy this violent engagement it would be appreciated.. Thanks Jim S |
[Reply] [No Email] | |
| jim sunnus
08-03-2012 12:30:03
64.180.192.74
Re: 970 in reply to jim sunnus, 07-28-2012 03:58:01
| Hello. I checked the springs & they are intact.It was mentioned in one reply that I could narrow down the leaking clutch using a flow meter. Could you tell me where to hook it up & what flow I can expect to find. Thanks for all your help Jim S |
| mEl
08-03-2012 14:44:25
108.10.129.170
Re: 970 in reply to jim sunnus, 08-03-2012 12:30:03
| jim sunnus said: (quoted from post at 12:30:03 08/03/12) Hello. I checked the springs & they are intact.It was mentioned in one reply that I could narrow down the leaking clutch using a flow meter. Could you tell me where to hook it up & what flow I can expect to find. Thanks for all your help Jim S |
A flo meter plugged into the remote couplers is easy, keep the load valve set lower than the pressure that the spool holding plungers kick out at or tie the remote on with a tarp strap, lock the remote that supplies the coupler on the inlet side of the flow meter and read the flow in each range, reverse and clutch down. A significant drop in flow to the remote in a particular range indicates that the flow divider is sending more oil to the power shift to make up for internal leakage in the clutches involved in that range, by knowing the clutch combinations you can easily zero in on the faulty clutch.
Copy the following, c1-c2 = 1 power shift----c1-c3=2 power shift-----c2-c3=3rd, Clutch down=c4 and r=c2=c4.
Check the flow in each of these ranges and write them down and by comparing between ranges the leaky clutch can be isolated.
Use the flow meter to warm the oil to get a hot oil test as that is more meaningful, oil at 150 to 180 should be good, running the hydraukics against a load will warm it up fairly quickly. Write or print off the above info as it will serve you well as you test.
m
This post was edited by mEl at 14:45:46 08/03/12. |
| jim sunnus
07-29-2012 21:02:27
64.180.192.74
| Thanks for the help. Do I have to remove the valve to check the springs you mentioned or can I do it in place ? Thanks Jim S |
| mEl
07-30-2012 03:46:33
96.249.140.201
Re: 970 in reply to jim sunnus, 07-29-2012 21:02:27
| Quoting Removed, click Modern View to see
In place, thoroughly clean the PS control valve area and especially the rear area, The springs and modulating point are at the rear end of the clutch spool and removing the plug there will give access to them, They usually come right out as the plug is removed if done carefully, bring the plug straight out and they may stay right on the roll pin that they ride on.
The assembly used to be available as a kit, get with a reputable old Case dealer who has a good parts person if you need help. |
| 1370rod
07-28-2012 05:14:13
69.179.26.71
| Theres a bunch of good repair guys that read this forum so I'm sure someone will nail your problem. My guess when you say inching pedal is extreme asuming you mean engages harshly when the pedal is just about all the way up after oil is warm would be 1 of 2 things. The spool controlled by the pedal has 2 spings under it. one heavier and a very light one seperated by a washer. The light one does compress with age, break or be slid up into the big one if washer is missing. Any one of those could cause that problem. Also if you had a small oil leak in the P. S. itself. The pedal controls oil feeding the P.S. when starting out and until the pedal is about 3/4 of the way up is fed through a 2 gpm. orfice. If the leak is greater than 2 gpm after the oil is warm (thin oil) the tractor will not move until the pedal is just about all the way up because then it picks up full pump flow and will engage harshly. This problem is ussually corrected by repairing the P.s. Rod. |
| mEl
07-28-2012 06:46:45
71.241.102.73
Re: 970 in reply to 1370rod, 07-28-2012 05:14:13
I agree wholeheartedly with Rod, the modulating plunger could be the problem and easy to check. More than likely the Power shift needs attention and if so I would pay the extra to update to the later style clutch pistons if not so equipped. If you have access to a flow meter you could zero in on the leaky clutch that is most likely the problem.
mEl |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
