Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 400 Diesel eng. block
[Return to Forum]
1370rod
07-24-2012 17:03:02
174.125.227.46
A customer removed a con. rod cap and brg. to bring to me to inspect and see if I thought the brgs. should be replaced. His son not knowing this hopped on the tractor tried to start it so he could move it out of the way, oops. Well you can see the results. I plan on either welding it back together or making a plate to bolt over the hole, any pro's or cons for either idea. Rod.
[Reply]   [No Email]
george md
07-24-2012 21:59:50
209.213.167.201
 Re: 400 Diesel eng. block in reply to 1370rod, 07-24-2012 17:03:02
Rod,
Don't make a mess out of it with a welder,
or a plate. Call lock-n-stitch ,tell them how
thick the casting is ,they will sell you the
plugs for that thickness, and also the tools
needed to lace it with their plugs . Grind it
to a square edge and fit another piece of cast
in the hole ( fit it tight ), I use pieces of
bath tub as they are very good cast iron. When
finished hit it with needle scaler and you will
not be able to see the repair. It is best not
to use the tapered plugs for that job as you can
overtighten them and bow the block .
Send me an email with a phone # and I'll call
you.
george
[Reply]  [No Email]
jon f mn
07-25-2012 05:44:28
166.248.8.126
 Re: 400 Diesel eng. block in reply to george md, 07-24-2012 21:59:50
I have heard of doing it this way before. I looked it up online and it looks very interesting. It should work good. I'll have to find out what it costs.
[Reply]  [No Email]
John Saeli
07-25-2012 05:27:53
66.66.16.240
George: I have a welder friend who welds his cast with a Mig using the regular wire a mig uses. He did a piece for me. Looks & held great. He said the mig doesn't develop the heat that the stick will. Any thoughts?
[Reply]  [No Email]
george md
07-25-2012 20:05:52
209.213.167.201
 Re: 400 Diesel eng. block in reply to John Saeli, 07-25-2012 05:27:53
John,
There is no such thing as cold or cool
arc welding as the arc is several thousand
degrees. The area surounding the weld is cool
and it will suck the heat from the weld area,
that rapid cooling makes the heated area
extremely hard and brittle.
george
[Reply]  [No Email]
jon f mn
07-24-2012 21:18:49
166.248.2.85
I've done it 3 ways, welding, brazing, and bolted patch. Far as I can tell the only difference is it's very hard to weld it with nickel unless you lay it down. Brazing or doing the bolted patch can easily be done without removing the block.
[Reply]  [No Email]
beagle
07-24-2012 20:25:29
66.115.224.199
i would nickle rod it together and grind it smooth. I would be more concerned about the rod, if it's bent or if the brg bore is knocked out of round.
[Reply]  [No Email]
outsidersag
07-24-2012 20:20:38
75.221.92.67
I would bolt a plate on it. got a 400 that had a freeze crack and that plate has been on that block for over 20 years.
[Reply]  [No Email]
dboll
07-24-2012 19:47:45
64.61.211.180
if you have the other piece I would see if anyone nearby can weld it with nickel,possibly Meaden's in Slayton?done right it can be dressed so as you will never see it, whenever I change oil or whatever the engine gets disabled so that it won't crank over
[Reply]  [No Email]
tomturkey
07-24-2012 19:21:31
216.81.211.253
What a shame. My tractor (411) was at my sons with the oil pan held on with two bolts and no oil while I got the new gaskets. I put a big sign on the steering wheel. DO NOT OPERATE THIS TRACTOR. I was very concerned that something such as this would happen. Wishing you the best success. Let us know how you fix it and how well it turns out. gobble
[Reply]  [No Email]
Chuck Machinist
07-25-2012 01:50:01
71.176.39.127
 Re: 400 Diesel eng. block in reply to tomturkey, 07-24-2012 19:21:31
I use the same procedure you do in my shop Tom> I am certainly impressed with the first repair from george md. I have made many cast repairs in the past and it makes good sense.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
