Yesterday's Tractor Co. Fast, Friendly Parts Service
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: caseomatic
[Return to Forum]
gene watkins
07-23-2012 19:22:32
67.236.132.206
i looked at 800 caseomatic . owner wasnt home mod.811b ser#8151203 1959 narrow front. has power stering. paint fair. transmision leaks. has gear shift. how does auto work. ihave ford selectospeed it is different. can i tow this tractor ford cant need to shift rear end out. motor has not run in years. thanks
[Reply]   [No Email]
Bret4207
07-24-2012 07:19:42
64.19.90.196
 Re: caseomatic in reply to gene watkins, 07-23-2012 19:22:32
Great tractors, outstanding tranny.
[Reply]  [No Email]
gene watkins
07-24-2012 05:17:59
67.236.132.206
thanks guys great help is their a way to stop leak at transmision without breaking in two?
[Reply]  [No Email]
jon f mn
07-23-2012 20:52:07
166.248.7.238
If the transmission is in neutral it is just like towing any other tractor because nothing will be turning in the com. Just make sure the brakes work for stopping because even in gear there is no engine braking. If you put it in gear it would be like towing a car with an auto trany.
[Reply]  [No Email]
casenut1
07-23-2012 20:44:52
107.8.39.45
So can you just apply the brakes, as long as not locked in , to stop.i have a 800 Case-O-Matic and am still learning how to operate it.
[Reply]  [No Email]
John LaBoyteaux
07-23-2012 20:33:02
76.14.94.14
The casomatic is a great system when running properly. Most maintenance in keeping the filter clean and full up with hydralic clean fluid. It uses CASE TCH or high quality tractor fluid.
The system is simple, it is a torque converter in front of a standard
transmission. There is no dry clutch. The clutch pedal is a valve
that directs or interrupts (dumps) oil flow to the torque converter.
Once in motion there is a lock-up for the torque converter which gives you direct drive.
John
[Reply]  [No Email]
INCase
07-24-2012 08:53:19
209.221.240.193
 Re: caseomatic in reply to John LaBoyteaux, 07-23-2012 20:33:02
actually, the torque converter is always going if the engine is running just like a car. The clutch valve dumps pressure and releases a clutch-pack that is inbetween the torque converter and the transmission. The direct drive is engaged by the lever to the left of the steering column and via hyd pressure and a cylinder engages a clutch locking the torque converter so there is no slippage and is therefore more efficient.
Pretty good transmission systems and you'll love once you get to use it but there are some problems. Plugged filters, warped clutch packs, worn clutches, bad seals (lets hyd pressure leak off), bad pump ect.
Good luck
[Reply]  [No Email]
gene watkins
07-24-2012 11:07:33
67.236.132.206
 Re: caseomatic in reply to INCase, 07-24-2012 08:53:19
biggest problem is he quit using when tranmision started leaking. could towing hurt trans could not find place to ck fluid. thanks everybody Gene
[Reply]  [No Email]
Case Nutty 1660
07-24-2012 11:50:07
75.127.24.27
 Re: caseomatic in reply to gene watkins, 07-24-2012 11:07:33
to check the trans oil pull the breather/dipstick on top of trans housing behind the shifter, to check the COM LH side of bell housing/COM housing it will have another breather/dipstick, as another said as long as the trans is full of oil and you have the gear shift in neutral it will not hurt to tow it, as to the leak I am guessing it is at the rear of the engine oil pan where it bolts to the bell/COM housing pull the oil pan and replace the gaskets and that shhould fix the problem, get the gasket set from Case I also like to coat the gaskets with a Locktite product in CNH pakaging call Gasket Eleminator it has 515 in the part number I can post it for you if you like very good product and makes a oil tight flexiable seal, cnt
[Reply]  [No Email]
old
07-23-2012 19:34:02
209.86.226.27
Yes they can be towed but I would not tow it very far. Ya if for say loading it and say less then a 1/4 mile go for it. Me I would make it run where it sits and do it that way. BTDT with one like that and was told it would not go forward and I drove it on the trailer
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
