Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Case 430 Hydraulic line flare fitting stuck
[Return to Forum]
hondaracer2oo4
07-23-2012 15:26:21
50.133.188.31
I have a pin hole leak in my Hydraulic line back to my backhoe. I need to removed the line which is connected with a flare fitting. The flare fitting is loose on the threads but is solid to the line and the both spin togeather when you try to unscrew the flare fitting. Any tricks on breaking the hydraulic line free of the flare fitting? Thanks.
[Reply]   [No Email]
hondaracer2oo4
07-24-2012 19:42:04
50.133.188.31
 Re: Case 430 Hydraulic line flare fitting stuck in reply to hondaracer2oo4, 07-23-2012 15:26:21
Thanks everyone for your help. The location that the flare fitting was at went to and elbow and then another flare fitting. Turns out the other flare fitting was no problem at all! So I took that one off and was able to remove a swivel fitting on the other end without even having to fool with the stuck one. Thanks again for everyones help!
[Reply]  [No Email]
hondaracer2oo4
07-24-2012 07:29:46
50.133.188.31
Thanks well give it a try!
[Reply]  [No Email]
rbradk
07-24-2012 03:25:39
24.46.39.139
I think you will find that the flare fittings collect stuff in the "hex"
end of the fitting. Try soaking it down with penetrating oil...use an
air compressor to blow the oil down in there. Heating the hex of
the nut and a bit below while keeping the line cooler will allow
expansion of the nut and yield a bit of clearance. slow back and
forth motion will help loosen rust and dirt.
[Reply]  [No Email]
hondaracer2oo4
07-23-2012 18:56:57
50.133.188.31
Mel,
Thank you for your insight. Not sure where you want me to heat though. The nut/flare fitting are one long piece. After the nut section of the fitting the fitting tapers down towards the end. At the end the hydraulic line comes out of the end. I would think that the location that the fitting is stuck on the hydraulic line is where the flare is inside. If I dont heat that where do I heat? Thanks!
[Reply]  [No Email]
mEl
07-23-2012 18:28:07
108.10.128.243
Heat the nut, but try to protect the crimp area, maybe soak a rag up with water and wrap around the fitting crimp. Have had to do this many times as rust takes over on old stuff.
mEl
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
