hondaracer2oo4
Recently aquired a 1966 Case 440 with the model 22 loader and backhoe. The brakes did not work at all. The clutch side I pulled apart and replaced the brake bands and springs and cleaned everything up. The left side now works great. The right side is leaking oil from the bottom drain hole of the brake cover. I assume bad seal. Has anybody done it or can confirm the part numbers I need of the seals? The two parts numbers I found of what I think I need are A49796 and 510828. Any tricks to doing this? I assume I need to drain down the oil to below the level of the output shaft. Does the plate just slide right off after removed the brake parts? Thanks.
