Radiator cap gaskets
1031D
I have a LA and DC that need new radiator cap gaskets. I just removed the LA one this morning because it was breaking up and falling in. Is there someone who sells them? Can you make one?
We threw them all away on our DC's. My Grandfather was burned really bad on his face when he went to check the radiator on a DC that was hotter than expected. They will seal and build pressure. I guess they would be OK on a pretty tractor in a parade, but all ours are earning their keep on the farm.
Yep, got myself burned by my C. After a July 4th parade I was by the front of the tractor and bumped the bail holding the cap on and it blew the cap off and drenched my arm with boiling antifreeze. Previous owner had put on a gasket and a insect had built a nest inside the overflow tube plugging it. I spent the afternoon and about $1,000 at the ER. I threw the gasket away after that, won't use one on any of my Cases.
good to know John really glad you keep these outdated parts in stock, you have any other options for a "70" series hyd pumps other than CNH? it PO's me what they are getting for them now thanks again cnt
