Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 1944 Case DC4 Valve adjusting
[Return to Forum]
Corbett in West Michigan
06-04-2012 17:45:56
50.36.69.50
Hi All, I put new push rods and valve springs in my tractor. Several of them had broken and the push rods were bent. Now I need to get the valves adjusted. Book says .018" I"m just not sure where to start. #1 at Top Dead Center?? Or...
Thanks so much, I appreciate the knowledge here!
[Reply]   [No Email]
06-05-2012 07:24:09
50.36.69.50
Re: 1944 Case DC4 Valve adjusting in reply to Corbett in West Michigan, 06-04-2012 17:45:56
Compression stroke, that makes sense, VERY important! I'm still learning all this stuff...
Thanks!
  [Reply]  [No Email]
Flewster
06-04-2012 18:42:19
199.192.208.89
Re: 1944 Case DC4 Valve adjusting in reply to Case Nutty 1660, 06-04-2012 17:45:56
The way I do it is this..........Loosten all the rockers so no valves are open. Then pull plugs and put finger over hole. turn motor till you feel compression on that cylinder and then adjust the valves for that cylinder. Then move on to the next one. I know its longer but it easy for me to do that way. With # one on compression stroke you can adjust #1 and #2 as #2 is on power stroke.
  [Reply]  [No Email]
06-04-2012 20:32:36
50.36.69.50
Re: 1944 Case DC4 Valve adjusting in reply to Flewster, 06-04-2012 18:42:19
So it's the same method for each one? Bring each cylinder up to the top, adjust both valves, and repeat all the way down the line. Doesn't sound too bad afterall, thanks!
  [Reply]  [No Email]
casecollectorsc
06-04-2012 23:13:17
173.27.65.36
Re: 1944 Case DC4 Valve adjusting in reply to Corbett in West Michigan, 06-04-2012 20:32:36
Not just to the top,it has to be on compression stroke!
  [Reply]  [No Email]
mEl
06-05-2012 04:44:44
108.10.132.171
Re: 1944 Case DC4 Valve adjusting in reply to casecollectorsc, 06-04-2012 23:13:17
All my career I have used the intake valve on the next cylinder to fire to locate TDC on the cylinder to be set. When the intake on #3 for instance has dipped and is coming back up and nearing its seated position #1 is on compression and near TDC.
When I build a competetion DC engine I fashion a permanent pointer on two bolts on the timing cover and mark the front pulley with a chisel mark after locating TDC with a dial indicator. this can be used to locate for setting valve clearance as well as running timing with an advance style timing light.
I set each cylinder at TDC, as opposed to the book method of setting several at one setting and major truck engine manufacturers have returned to this method as well in recent years.
Just a side note, If you are using 60-70 year old cams you would not believe the wear on the lobes and cam follower lobes. A reground cam and resurfaced followers will really perk a DC up.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
