Case 930 Injectors
The 930ck that I recently aquired has an audible noise coming from the #1 injector, I'd like to swap a injector from another cylinder to see if the noise moves with the injector or is associated with the cylinder. Are there any tips or tricks out there to make this a sucessful endeavor? Are the injectors from a 730 the same as those in a 930? Are there any good online sources for injectors?
Thanks in Advance..
Southside
Hello,
Yes the injectors are the same for a 930 and 730. I would also look at your valve lash that could be the noise you are hearing.
Good luck Ed
Thanks Gene !
Moved the injectors around tonight, and the noise is still on cyl #1. I'm gonna order new copper washers for the injectors as some appear tobe leaking. Next step is to remove the valve cover and check the valve lash....fingers crossed!
Thanks for the replies
