70 series brakes
steve il
when turning the steering wheel applies the brakes, ive been told by some mecanics that the brake housing is bad and must be replaced. others say it is repairable. what are you guys experiences? thanks Steve
I assume it has power brakes. The boost spools in
the brake valve are stuck. Remove the brake lines
from the front of the brake valve by using a 3/4
inch wrench to banjo bolt. Do not loose the 2 copper
gaskets. Use a 7/8 wrench to remove the next
fitting. The boost spool is next and there is a
spring behind it. Use a snap ring plier to remove
and free spools.
(quoted from post at 06:11:00 03/04/12) when turning the steering wheel applies the brakes, ive been told by some mecanics that the brake housing is bad and must be replaced. others say it is repairable. what are you guys experiences? thanks Steve
The advice given is right on, however there is a reason generally why the spool gets sticky. Contamination is getting past the filters and getting to the affected spools from dirty filters or missing bypass reliefs in the bottom of the filters.
I would change the filters and check that the relief cartridges are in place as I have seen many that were missing as they were stuck in the old removed filters and not in place to stop oil from bypassing the new filter. If it has been a considerable time since a complete oil change has been done on the tranny I highly recommend that you do so.
In my opinion only Hy Tran Ultra should be used in this system, others will disagree but I have worked for the same dealer a few months less than 50 yrs and have first hand repaired the results of "will work oils". The Gent who had to replace every lined disc in his 1370 will not disagree with me but many will. I have made a living giving good service and advice so have a thick skin when it comes to criticism.
mEl
mEl as always great advise on the Hy-Tran use I completely agree the small amount of money saved by using a "cheaper" oil is not even close to the repairs that can come from using them vs the Hy-Tran oil, all of my 40 plus tractors of mine that I use regularly all have Case oil them from front to back I have never had a oil related problem and as you said I also have close to 50 years with Case equipment in service and sales cnt
I was leaving for church and I knew that there was
plenty of good help to finish Steve il with his
tractor needs. This is a great forum.
I'm the one that had to replace ever fiber disc in the 1370.
I purchased what I thought was a cherry 1370. I replaced the oil with oil that I use in my 930's for convenience.
I thought I was using Premium oil and not some cheap stuff. I even asked the local dealer that sold me the oil if it was rated for the 1370 case
Needless to say the oil I used was not cheap it actually is only a few dollars cheaper than Hytran Ultra. My nearest case dealer is 43 miles away my oil supplier is 3.
Here is what I learned
Hytran has NO zinc in it and does not create corrosion in hydraulic systems like other oils.
Hytran also has the ability to absorb/disperse water up to 1% of the volume of oil.
I learned a costly lesson by not using Hytran Ultra.
In my defense it was ignorance on my part, like I said, I thought I was using premium oil.
Since my lesson I have learned that there are 70 series tractors out there with 7-8000 hrs on them that have never been touched.
The difference is Hytran Ultra!
