A couple of you have aermores on post-crossmotor tractors. I plan to put one on a '29 L and will have to build a valve. I have two designs that are based on Don's photos from a while back - one with a single butterfly that blocks the outlet and forces exhaust up through the whistle (like original) and a second design with an additional butterfly that closes the whistle bung when the main butterfly is open. The reason for this is that it appears that automotive valves had the second butterfly. I know original L and C valves only had the single butterfly, but I don't want the whistle to make noise when not in use. I've also thought about installing a fixed deflection shield before the whistle bung to encourage the exhaust gas to skip that port unless it's forced there when the main butterfly is closed.
So, what have you guys experienced with your whistles? Do they make any noise when the valve is open? I'd appreciate any info or pictures you can provide. I've already combed the forum archives several times, which has helped a lot. I have a No2 and a No00. Hopefully the L can blow the 00 and I may use the 2 on a 1930 C someday.
