Case forage harvestor model?
Anybody know the model of this harvestor? A friend of mine found it while hauling iron and offered it to me before hauling it in. I decided to take it and would like to know the model so i can look for a parts book and operators manual for it. Thanks!
I think its a "200" series I will look up some lit on it for you and post, you might check with Jim and Tim Miester for the books, I can send it to you if you like cnt
I have one like that, it's a 212. Yours might be a little older, since it has round spoke wheels. Mine was the first one like that I'd ever seen, so I had to have it.
Looks just like the one dad bought new in the mid 50 s & it was a model C 2. Lift lever, spoke wheels , spout & other things all are the same
Case s first verson was a model C , pretty much like this one , biggest diff. was the discharge spout , it was a very high spout that was not good .Dad bought a C new also the first yr. they were made , about 1947 or 48.
Latter ones had disk wheels & quick change heads . clint
THat chopper looks in great shape , I would never paint it as it looks very nice now. Remember , you cannot unrestore a restoreation job.
Looks like it would go to the field and work .
They were a easy running machine , I had used dads for years with a ' hopped up' DC " pulling it and a wagon. clint
My father had one just like in your picture with both hay & corn heads from about 1948 to 1960. He 1st pulled it with a Farmall F20 and then a Farmall M. He traded it on a new Gehl chopper and then found out his Farmall M couldn't pull it in heavy corn. Had to put an engine on the Gehl. He always said the Case was a very easy pulling chopper. The attached pictures don't show much of the chopper but it is the only one I have. Picture taken in 48 or 49 when I was about 5-6 years old. Al
Had one like that back when we started dairy farming, was a Case 220. They also made a 210, the 220 had 6 blades and I thick the 210 had 4. Easy to run in the thickest corn, pulled it with a DB 990. Had a pickup, a direct cut head and a one row silage head. Case also made a corn head that would snap the ears off and run them up an elevator into a trailing wagon and the stalks were chopped and blown into a wagon pulled alongside. You could also take the bottom band off the chopper and shred the stalks back on the ground or there was a door you could open and drop the ears back in the chopper to make silage. Don't think any one else made a head like that. Have a new set of blower pattles, if you need them. May have a manual. That's a real nice find, glad it's not getting scraped. Tom
Almost looks like the corn head and the cutter are different ages. There is a serial number plate on it (can"t remember just where) that will give the serial number and age. My bet is on a C series mainly because of the spoked wheels. Have both a 210 and a C and there are some subtle differences.
The chopped dry hay and straw was blown into the barn using a blower. Almost no chopped dry hay is made any more as most bale it. Al
Here's the brochure on one of those Tom.
Says the Corn Harvester fits either the standard or long cut "Quick-Change" Case "C-2" Forage Harvester base machines.
Thanks guys for the info! I'll get more pictures when i go pick it up this weekend. I bought it just by the picture above. I was able to find a parts book and operators manual on ebay today so i got that covered. Thanks for the pic of the brochure. Are these complicated to work on and get going again if they've been sitting awhile? I can't say i've ever seen one of these up close.
