It is equal to or better than anything else of the time in it's class. Check the brakes, they may need new discs. they are easily available but could cost a bit. If it has power steering it will be a little weaker than say a jd or Ih, but is very usable. Check Hydralics, pumps are getting hard to come by if they are weak, altho they are very reliable, which is why there are no after market one available.
OK thanks.
Now I just have to get time to go look at it. It has a loader that will not stay on it if I buy it as I have 2 other loader tractors. It's right where I need one in that HP range.
Rick
I have two of them. One narrow front and one standard wide front. Both power steering. GREAT tractors. Only problem for me is changing from high range to low range. Very close pattern there. Use both of them a lot and no issues to worry about. Good luck with it.
