Case 310 backhoe weight?
Tuna IL
Any ideal on the weight on a 310 B/H, I need to move it about 200 miles. Trying not to overload my 7k car trailer. Tractordata list tractor as 3200 with out loader or hoe, a ck530b/h is listed at 9000lbs. It is a round nose. Other thought how much weight might I save if I pull the buckets off for the move?
thanks
charlie
my book shows 7740lbs for a 320, same basic unit but the 320 has a self leveling loader, so would guess that you could take 150-200lbs of the 7740 weight, loader bucket weight 200-250, backhoe 125-155 depending on size
I wouldn't risk it. The 7k rating on the trailer includes the weight of the trailer which is about 3k or so. get yourself the right trailer (rent or borrow) and save yourself a lot of headaches. good luck!
Brian
When we moved my 320 backhoe we used a deckover 15K lb gooseneck with a 1 ton dually (not mine unfortunately). My buddy the driver said that he could tell it was back there. Wasnt easy pulling but it wasnt struggling either.
Frank
Thanks CNT I had looked forever and could not find the weight. I brought it home with a 09 dodge 2500 longbed on a 7k trailer not knowing that it was that heavy. Will go with loading it on my 53' stepdeck to be safe this time.
thanks
charlie
My book for a 310B lists the combined weight of all three as 7658#. I brought it home with a 15,000 goose and a good ol 460 Ford F250, 5 spd. Pulled right nice...............
