Hello,
I bought a Case 410 (gasoline) tractor a few years ago, used for odd jobs around the yard. It was in reasonable shape, but required a bit of maintenance. One of the things I did was change the spark plugs, and spark plug wires.
Everything was OK for a while, and then I started noticing a “miss” in the engine. Tracked down the missing cylinder, exchanged the plug with one from another cylinder, the miss moved with the plug. So I replaced the plug, and all was well (for a little while).
Then the miss returned, so tracked down the offending cylinder again. This time I pulled the wire at the plug to see what sort of a spark I was getting. I held it about ¼ of an inch from the plug, looked like a decent spark, but much to my amazement, the engine smoothed right out, the miss was gone! As soon as I touched the wire directly to the plug, the miss returned. I repeated this a number of times to confirm that this was really happening.
So far, no one I’ve talked to has been able to come up with any suggestions as to why this is happening - I hope someone on this forum will be able to help me.
Btw, I’m using Champion D16 plugs, I’ve been told these are the correct plugs for this tractor.
Thank you,
Regards,
Dave
Thank you,
Regards,
Dave
