Quick question on amp meter. I hooked the wire from the generator to the right terminal (as looking from meter face to down through to the back of meter) and the left terminal to the light switch and the battery positive cable. When running the tractor shows about an 8 amp neg charge. I just assumed that the guage was hooked up wrong so no big deal i would change it later. trouble is the battery is not charging. I show 6.37 volts when tractor not running and 6.66 volts when tractor running and at normal RPM's. Could it actually be that the battery is being discharged by a bad regulator? Is my meter hooked up right?
