Stephen Newell
I need help identifying a Case Tractor I bought.
It was made by JI Case. It was sold to me as a Case 300 tractor. After receiving it I found that someone hand painted 300 on the side of the hood. I later found a plate on the dash which had many coats of paint on it. After cleaning the plate off it was stamped 210 B-H. I assumed the tractor was misidentified until today when I stripped the paint off the side of the hood and found that at one time it had a factory decal 300 on it. This part of the hood looks original however the large piece on top looks like it had been modified from another tractor. Now for the facts. The tractor is 56 1/2" tall to the top of the steering wheel. It is about 76" center to center from front to back wheel. It has an overall length of 127 1/2". It has a 4 cylinder gas engine. The radiator cap protrudes above the hood as well as the breather to the valve cover and the gas cap. The front section of the hood with the headlights is solid metal with no holes cut into it for any access. The tractor has power steering that the reservoir is filled on the side of the engine. It has a Dual-Range Shuttle. It has a 4 speed transmission.
