deerefanatic
OK, this CK that I worked on this winter is back with a new problem. The 3 point is working ok, but the remotes have no power. They'll move a remote cylinder in and out, but won't lift anything. Put a pressure gauge in place and there's only 500 psi pressure. Pulled the auxiliary valve off and took the pressure relief valve out. Cleaned that all up with brake cleaner and inspected it. All looks good. Still no better.
this is the early style auxiliary valve with the pressure relief mounted on the bottom. the tractor does have DOM....
I'm wondering if it's the hydraulic pump or the suction o-ring I'm going to dig deeper into the suction o-ring possibility here tomorrow.. Just wondered what else it could be?
Thanks.
-Matt
Thanks.
-Matt
