I was just working land to plant some beans this morning and my Case 2870 died. She started loosing power like it was starving for fuel and then finally died. The injection pump is not putting out any fuel to the injectors. Oil pressure, water temp, exhaust temps were all good, seemed to be operating normally up to that point.
The lift pump (which is mounted on the side of the IP) is definitely working, there is lots of fuel at the banjo fitting going into the the IP when I turn her over. Filters and strainer are all good. No sign of water in fuel, I drain the water traps in the tanks and the primary fuel filter regularly.
Before I remove the injection pump and cart it off to the fuel injection shop is there anything simple to try?
Thanks,
JP.
Thanks,
JP.
