Topic: Case 300 Clutch
[Return to Forum]
| Author |
[Modern View]
| jasonbickel
05-30-2011 18:31:03
99.63.30.81
I recently purchase a 300 triple range unit, runs good, however the clutch wouldn"t release. Split it and the clutch disc had fallen apart, couple of springs in the center of the disc spit out and the friction material was spit out in a couple of spots. Needless to say, the clutch disc is not repairable and I need a new one. Does anyone know where to get one from? Is it possible that a VAC clutch matches? Also need to get a new throwout bearing as well, bearing is good but the other end of it has worn away significantly about 1/8" or so, the spring was put in backwards.
Any input is appreciated. Thank you, jason
link to pics of the tractor:
http://s1201.photobucket.com/albums/bb352/jasonbickel1980/case%20300%20tractor/ |
[Reply] [No Email] | |
| jasonbickel
07-03-2011 15:13:58
99.63.30.81
Re: Case 300 Clutch in reply to jasonbickel, 05-30-2011 18:31:03
| Update, I have the tractor back together. Ended up having to reuse the piece of the throwout bearing that was worn down. It did separate from the throwout bearing easily using a chisel and then just press back together with the vise.
Got a new intake/exhaust gasket installed, adjusted valves, replaced valve cover gasket. Runs excellent now.
Replaced rear crank seal since I had it apart. Replaced hydraulic pump seals as it was obviously leaking, not sure if it fixed the leak though as I have a drip from the bottom of the bell housing.
Changed out rear axle seals, they were leaking pretty good. Replaced gear oil.
Would like to see if I can find a match to the one good tire I have, it is a BF Goodrich Silvertown 13.6 x 28. If anyone has one that is about as good as the one that I have i am interested.
No restoration for now, will just put back together and enjoy for a while!
This post was edited by jasonbickel at 15:15:29 07/03/11. |
| BarryfromIA
06-01-2011 19:01:29
67.55.176.9
| The center cushioning springs will tear the spring pockets apart and break after a full season off running a hay baler. We noticed some thing could be wrong when small pieces of steel were falling out of the slot in the clutch cover. |
| Joe Young
06-01-2011 05:32:29
99.109.60.138
| | Hey Jason First...It looks like you have a good helper for this project... Second...It looks like you have a unique little 311 to restore. I'm looking forward to the pictures when your done with the restoration.... I just ordered rod/main bearings, a full gasket kit and a clutch kit from AgKits.com for my 312 restoration. Several of the items were drop shipped from different locations, but all arrived within 3 business days. The parts are first quality stuff (Clevite, Federal Mogul, etc) The clutch kit includes the clutch disc, pressure plate and bearing. While you have the tractor split be sure to install new seals, o-ring and gasket in the tach drive assembly in the rear of the bell housing. Joe (Wa) has some great pictures and details on the process here. (Thanks again Joe (Wa)... your detailed explanations and pictures are very helpful). |
| mEl
06-03-2011 11:54:39
64.134.188.121
Re: Case 300 Clutch in reply to Joe Young, 06-01-2011 05:32:29
| Quoting Removed, click Modern View to see
Joe Young, Was the kit you ordered, a standard bore or the 3 7/16 overbore? Our suppliers no longer supply the big kit, just 3 3/8. Always trying to keep one step ahead on whats out there. mEl |
| Joe Young
06-04-2011 05:38:43
99.109.60.138
Re: Case 300 Clutch in reply to mEl, 06-03-2011 11:54:39
| | mEl I didn't order the full overhaul kit...just the bearings (rod and mains) and the gasket kit. It appears they only offer the standard bore kits on their website, but a call to them may prove otherwise. I found them very helpful when I called to ask few questions. - Joe |
| JPFL
05-31-2011 05:42:43
173.65.220.177
| I have a used ceramic set us out of 211b if they will interchange. Jim |
| Joe (Wa)
05-31-2011 00:16:27
67.142.175.27
|   VAC & 300 clutch plates are different size & configuration. John Saeli should be able to provide the clutch parts. Spark ignition 300 standard duty single plate is Case p/n G11077, plate-9.25" dia, 10 spline-1.125" dia. Single plate clutch release bearing is Case p/n G10610. Your pressure plate pic doesn't look quite right, maybe just camera angle? Can you post a head-on pic? Release bearing mounts on the hydraulic pump drive shaft as in the pic. Spring behind the bearing is mounted small dia end aft as shown and tensions the bearing up against the pressure plate levers, bearing notch shown at 12 o'clock catches on a pressure plate lever. The pressure plate, release bearing, spring, and hyd pump shaft all rotate as one. Joe |
| jasonbickel
06-01-2011 18:13:17
99.63.30.81
Re: Case 300 Clutch in reply to Joe (Wa), 05-31-2011 00:16:27
Head on pic of pressure plate added, believe to be correct
Throwout bearing was installed backwards as well as the spring. Bearing was worn way thin on the solid end of it:
Clutch disc was pretty torn up as well:
Did come across a website, www.hphparts.com that sells replacement parts and they have the clutch disc for $106 and the throwout bearing for $31. Did get ahold of a Sachs list of clutch dimensions for cars and there is a late 70s Buick application that has a 9 1/8" disc w/ the correct shaft dia and spline count. The disc (non-sachs) can be purchased at autozone for $25... half way tempted to buy one just to see if it will work. Don't think the 1/8" smaller diameter will matter much.
I'll contact Saeli as well.
Thank you all for your input, not sure if I will ever get to a complete restoration but at least I will enjoy it. I'll keep everyone updated on the progress.
Jason
This post was edited by jasonbickel at 18:15:09 06/01/11 3 times. |
| Joe (Wa)
06-02-2011 09:27:07
67.142.175.26
Re: Case 300 Clutch in reply to jasonbickel, 06-01-2011 18:13:17
| | Case release bearing G10610 is ~$100. I would be leary of a $30 bearing, especially greaseable. There is no access in the bell housing for greasing, you should use a sealed bearing. Joe |
| jasonbickel
06-03-2011 08:11:56
97.65.252.93
Re: Case 300 Clutch in reply to Joe (Wa), 06-02-2011 09:27:07
Purchased this from Saeli Implement, guess we'll find out. Agree that there is no way to grease so that option won't be a benefit.
Also, I did go ahead and order the automotive clutch and the tractor clutch to compare the two, will make a decision if it will work. If it does work I'll take a small finders fee :lol:
The guy had run a brush hog through some heavy timber and brush so I figure that's what did it in. Probably snagged a few stumps or rocks. |
| VACLee
06-01-2011 18:34:37
74.243.148.137
| Most automotive disc will not work due to the hub being to thick. If you look at the original it is almost flat on one side. The automotive style will rub on the collar that drives the hydraulic pump and tach. You can machine them to clear but the springs don't hold up in the center very well either. The tractor disc is much stronger. The 200b, 300, and 300b are the same, but they also had an option for a double disc which is smaller in diameter. Lee |
| george md
05-30-2011 19:41:17
209.213.167.201
| Jason, When you install the release bearing and sleeve, it goes in what looks to be backwards. The sleeve goes toward the clutch and the bearing goes to the fork. Reason for this is the shaft that the sleeve slides on is turning all the time as it is your live hydraulic drive. george |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
