I am finishing up the engine rebuild on my 1944 VAC. It is a first production model with chicken roost steering. I know there are quite a few differences in parts all over the tractor, but the books say the engine parts all interchange. The crank was bad so I put one in from a 1947 VAC. Put everything together, put on a flywheel and clutch, slid it in and the throwout bearing doesn't touch the clutch, rod is almost out of adjustment. Took the engine back out, changed to a different flywheel and clutch a couple times, same thing. Took it to another VAC that is waiting for an engine and same thing. Is the first production block machined different? Crank longer? I had a VT328 engine in this tractor for a couple years from a parts tractor, everything ran and worked fine but wanted to put it back to original. I laid 3 flywheels side by side and took my caliper and checked all the dimensions and all were close. Only variable I can figure out is the crank is shorter. I put the flywheel on from the 1947 donor tractor and same results. I have both versions of a VT149 block on the floor and a couple VT328's too, all external dimensions seem similar. Anyone else have a similar problem???
