Clyde.stanley
I have a Case 430 Diesel tractor with a 4 speed transmission, Draft-O-Matic hydraulic systems and discovered that the fluid is milky in color. Just had the engine rebuilt. Is this condensation? Or rain water ending the gear shifter?
Also just hook on a log splitter that I picked up. Maybe it had some bad oil in it?
I also need some clarification on the fill point - Dipstick (s) on the case 430. Two plugs on the left side.
(1) One at the front section.
(2) One further back be hide the shifter under the seat.
Is this a common reservoir?
What type of oil goes in here?
How do I drain it? One drain plug
How munch oil is in the system?
Thank you
Clyde
Thank you
Clyde
