Hope someone can help. Last fall, my battery died (Crappy battery that dies if not revving a lot. Common occurance) and my machine quit with a loud backfire. I charged the battery and when I tried to start it, it popped and backfired, but wouldn't fire. I tried purging water, and everything else I could think of, but it was already snowing so I covered it until spring.
Today I went out and drained all the fuel traps and started troubleshooting. I have 90 lbs compression in all 4 cylinders and all 4 plugs fire nicely. I tried to start it and in did just like in the fall. I pulled the distributor cap off and cranked it and saw that everytime it went over TDC, the rotor button was 90 degrees off. I thought maybe someone had played a joke and moved the plug wires. So I pulled all the plugs and made sure each was right. First crank and it started right up, but doesn't take throttle and just idles.
My guess is that it jumped the timing chain, but that doesn't make sense that it had good compression.
Can someone offer any opinions on how I should proceed? How does one check the valve timing, etc? Also, I noticed that the rotor button doesn't just turn, it snaps from one 90 degree position to the next. Is that normal?
Thanks in advance for any and all help.
