Case 65 front end loader
cj315
Hello all...I just purchased a 1210 David Brown with a Case 65 front end loader. It is missing the 2 legs or stands that support it when the loader is not attached to the tractor. Does anyone know where I could find the 2 stands?
Thanks
cj
I can't find my 65 book this is a 55, this what your looking for??? thought a photo would help cnt
thanks for the photo.... But The stands I am looking for mount up closer to the back of the loader near the pivot points in front of the hydraulic levers...There is one on each side...
Though I can't help you with stands, I may be able to help with your search. The Case 65 loader was built for them by Great Bend. If there are any dealers around that sold Great Bend, you could show them the Case manual. They may know of someone that has the same model. You could use them as a pattern to make your own.
That is the stand....Parking stands...I guess I will have to make them myself...shouldn't be too hard...thanks for the pictures....
that's what I thought they should looklike, yes GB is still in buisness, I am sure you are not close to me but I have a set of stands from a model 70/75 Case loader which is the same as a 800-900 GB if you like I could post them for you cnt
