Hey guys,
Since a deal I had made on a tractor has fallen through, I have decided to get some things fixed up with the money, so.. I'm looking for some parts for my 930 (pre-comfort king)
It's a 1962 model, diesel, and I'd like to find the following:
Water pump pulley.. Mine has a chunk out of it, so it should be changed.
Gauge cluster.. I have the "square" gauge inserts.. 4 small ones along the top (fuel, oil press, water temp, and amp) and 2 bigger ones on the bottom (RPM/Hour meter and speedo?)
The gauge cluster was wiped out, and I managed to find the 4 little gauges to kinda fix my panel (still no speedo/tach), but the chrome ring and glass are still messed up.. The tractor was pulled from a barn that caught fire, but had already got hot enough to melt seat cushions, break the glass in the gauge cluster, and char a little paint, and the chrome ring also.. Luckily, that was the only major damage. I cut plexi-glass for the cluster, and working so far.. but not "correct".
I need some other things also, but these are the 2 most important at the moment. My tax return check should come one day next week, so trying to line up some parts..
Let me know if you can be of any help.
Thanks,
Brad
Thanks,
Brad
