tluchterhandt
I need some help on understanding the adjustments for the PTO Clutch and for the PTO Brake.
Manual says that the PTO lever should have 70# of pull, is this 70# from the disengaged position all the way to the brisk snap as it is fully engaged? Or 70# at the brisk snap?
Also on the PTO brake adjustment, on my 830 the PTO is turning with it disengaged. Should the brake be adjusted until the PTO shaft stops turning? That is the way I understand the manual. Then there is a NOTE, that says, with tractor off turn PTO shaft by hand and there should be some drag from the brake until the lever leaves the neutral position and is almost fully engaged, then it will have no drag. I cannot turn my PTO shaft by hand at all, but it turns when not engaged.
And finally, how the heck does a big ole boy squeeze between the 3=point, and the fender and get his big ole hands in that small hand hole?
Thanks
Terry
Thanks
Terry
