tluchterhandt
I'm a bit confused here and could use a little help. I have play in the steering shaft from the gear box toward the steering column. After investigating and removing generator and lower radiator hose I find that the front U-joint which I suspected the problem is fine. But the entire gear housing shifts (rotates left to right) as I move the steering shaft. So the gear housing is loose in it's position where it rests.
What I suspected was that there was suppose to be a large collar ring under the bottom side of the gear housing that is suppose to bolt to the under side of the front of the tractor. There are 6 holes around the gear housing under there. In looking at the Case IH parts search page, I come up with what is called a ring -steering gear support part # A33869. It has 6 bolt holes in it also. This ring, as far as I can tell is not on my tractor. Am I on the right track here, or have I misunderstood something about the parts breakdown? The ring I refer to is in a box in the breakdown all by itself, not showing how it attaches. Any help will be appreciated. I went out and took a picture of it and the photo shows the bolt holes around the housing and also appears to be a ring where the part in question would go.
