mikefromiowa
Ok, Still think I have problems with my generator. I stuck a volt meter on it and got fluctuating voltages ranging from 0-11. Typically up to 8.5-9volts. Seems a little too high from what I have read. 7.4 is norm? I'm assuming its fluctuating due to the regulator. I'm assuming its either high charge or low charge. I don't think its a step regulator. I know its charging, the lights are brighter than they used to be. That makes me wonder if the voltage is too high. Will adjusting the 3rd brush change the voltage or just amperage? Remember it charges about 18-20 amps at normal engine speed.
