Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Case 1070 Power Shift problem
Dave52233
07-09-2010 10:21:20
This is a duplicate post for one on "TRACTOR TALK". It was suggested to be to post it on the CASE forum as well. I am going to include the reposes I already have from the tractor talk forum.
I recently purchased a 1070. It seems to work OK during spring field cultivating and planting. However, every now and then when shifting the power shift from 1st to 2nd, it would seem to miss, as if it was shifted into neutral. It would usually grab a second or two later lifting the front end up. Second to third always seems to work OK. The transmission does not seem to slip in any gear or range. During haying this summer, the misses have gotten more frequent. Also, once or twice, I while planting 60 acres, I pressed the clutch in and the transmission did not seem to disengage. It only did it twice and has not done it since. Does this symptom sound familiar? Any ideas what may be the issue, how I narrow it down and how expensive will it be to fix? Where can I get parts?
kent b
PostPosted: Thu Jul 08, 2010 9:21 pm Post subject: Re: Case 1070 Power Shift problem Reply to specific post Reply with quote
Sounds like it could be a poppit in the power shift valve. They can get a little bit of metal shavings in there and stick. Take them out and clean them with brake clean and a rag. I have done this and it works. My clutch on a 2390 did the same thing and it would hesitate in the power shift, i took them out and cleaned them. Works great now.
Posted: Fri Jul 09, 2010 8:58 am Post subject: Re: Case 1070 Power Shift problem Reply to specific post Reply with quote
My 1070 was worse than that when it came here . not only was the p/s cables way out of whack .. Previous O ,, JAmmed the range selector up bad , to where it only had 2nd and 4th range . those minor problems made the tractor a cheap buy for me .. sent it to friendly case/ihc dealer, who had all in order in 12 work shop hours .. the CASE p/shift automatically should return to 1st from any forward gear 2nd or 3rd ,, to decrease wear on delicate cable adjustments mechanics told me long ago to physically ues the hand selector for each shift . up as well as down shifting ... case p/ashift is not supposed to return to 1st automaticaly EVER ,when in reverse ,,,think About it ,,, That would be He!! on any being mechanical or human ,, these issues could be answered best over on Case forum.. i FEEL THAT THE CABLE ADJUSTMENTS NEED FINE TUNING ,, . AI/T book can walk you thru it...
Adirondack case guy
07-09-2010 19:49:27
 Re: Case 1070 Power Shift problem in reply to Dave52233, 07-09-2010 10:21:20
I have seen many posts on RPS34 trans. shifting problems. The first thing you should do is drain and replace the trans. fluid. On 7 through 1070s change both hyd. filters. The cast bottoms on the filter cans on them can be difficult to remove. Some times requiring a tourch or heavy hammering around the threaded area of the filter housing. Many owners have screwed the bottoms off the filter cans and never noticed the cold oil relief cartrige that fell into the drain pail. They installed a new filter without it and the new filter did nothing, thus allowing contaminents to flow through the entire PS system.If you are lucky, an oil and filter change will cure your problem. If your not, you will have to remove the pilot spools,and clean them as previously mentioned. Continued operation will cause clutch damage in the RPS34 clutch packs and a complete overhaul will be needed.
Triplerange
07-09-2010 17:34:37
Dave...I saw your exact same post on NewAGTALK forumn and agree with the replies there. First make sure your range selector lever, linkages and brackets are all adjusted properly. Take the cover off the platform (steel plate) and you will see the valve body. When the oil gets dirty the spools will hangup..and the tractor wont shift properly...not to mention damage other more expensive parts. You need to slide the spools out and polish them up. Make sure you change the oil in the trans. every 1000 hrs. Change the hydraulic filters every 250. (might have that backwards...if someone has an operator's manual they can verify. It'll be tomorrow before I can get to mine.)
Copyright © 1997-2015 Yesterday's Tractor Co.
