930 clutch question
steve il
i put a new clutch in our 930 and pressure plate fingers are in to far, theres not enough travel left to release. i though the 6 pad was to thick so i tried fiber clutch, same result. anyone know the measurement for the release fingers height. any help would be appreciated.
I had a 1965 foot clutch 930 that had the same problem. My son and I went in the hand hole and adjusted them to the throw-out bearing and measured to the throw-out bearing. Never had another problem. It was a pulling tractor.
(quoted from post at 18:23:07 06/05/10) i put a new clutch in our 930 and pressure plate fingers are in to far, theres not enough travel left to release. i though the 6 pad was to thick so i tried fiber clutch, same result. anyone know the measurement for the release fingers height. any help would be appreciated.
A dumb question probably but did you remove the bolts that keep the pressure plate compressed till it's installed? I have seen carryout customers have to resplit the tractor to remove them, not all models that use that PP have handholes to access that area. mEl
(quoted from post at 11:43:38 06/07/10)
yes, i removed them. but first time i took it out i didnt compress it. could the fingers have gone over center or something when it was spread out. thanks for your ideas guys.
