Case 2870 Planetary Ujoint Replacement
jogl
Do I have to remove the wheel, planetary, planetary housing, spindle and spindle housing to get at a bad ujoint?
I started taking out the screws that hold the ujoint retainer caps and then got wondering if the slip joints would move far enough out of the way.
Thanks,
JP.
SZ:
Thanks, I was able to get it off. I see that it is a Rockwell u joint. Should I be able to get these u joints at a truck supply shop?
JP.
Thanks for the info guys.
Local truck shop had one on the shelf.
Sure is a lot easier to work on with the wheel off. I was changing wheel spacings anyways.
JP.
