Anonymous-0
So, I bought a 1030 case on craigslist that supposedly just overhauled for $3500 (western style)
Well, the trucking cost me $1200 which I knew, but when I got it I realized it didn't have a drawbar and had all but one really bad tires.
Driving to the tire shop I realized the front axle was totally shot as well as the linkage up there and on the side of the motor down from the stearing wheel.
I brought the tractor to a guy I know, had him take the front axle apart so I could get everything rebushed and pinned.
We put it back on and noticed the steering pump was bad and replaced it.
When the tractor was at this guys place we noticed that the altenator was bad as well as the wiring for the whole rest of the tractor up to the gauges and lights.
After all this was fixed, I brought it to a dealer to get the rear wheels moved in for corn rows and to dyno it.
Turns out the pto clutch was totaly bad as well as the hydraulic pump and valve.
Put a new hydraulic pump on replaced all the filters and took valve apart and still don't have much pressure.
Now we also see that the fuel line is leaking, there is water coming out of the head gasket when it gets hot, a bad rear axle seal and the cast on the main housing under the axle has been J.B. welded.
Point is I have about $12,000 into a $3500 tractor and it still is not in good working shape.
Watch yourselves buying on craigslist!
