Fellas I sure could use some help understanding how this linkage works........My late 60's Case 580 (same as 530 for this question) runs great but will not throttle up correctly and I discovered that the guide/stop plate that affixes to the block and connects to the double springs for the gov is broken. The small stop tab on the guide bar is missing. PART ILLUSTRATION # 18 in the Case online parts reference for 530 Tractors.
I understand the double springs; the little one inside the bigger one and I am certain that these hook into the guide rod assembly as shown in the illustration and provide tension when applying throttle but do not understand how the guide stop slider plate factors in to the operation of the throttle linkage and will allow me to go past high idle as that is all I can get with the slide stop bar not attached....does the plate stop the guide at the stop and then allow one of the two springs to react opposing the other and somehow push the throttle open further?? I can not see how the addition of the slide stop will help me control the throttle UP past high idle.
I hope my question is framed in a manner that makes sense. Simply put I increase throttle and get very small increase even though the throttle linkage is moving a great distance but not enough to cause the carb linkage from the gov to move enough.....now I know I do not have the broken guide plate stop bolted on yet but I am missing how that will help push that linkage ahead further to allow the gov linkage to open the carb bigger. The case parts drawing seems very simple but I sure am thinking I am missing something.
I am gonna weld a small tab on the guide stop plate to fix it and reattach to the block but that part seems to be designed to control how far BACK the throttle can be pulled and my problem is i want more??? Can you help by explaining the way this is supposed to work ? Thanks
