Case 480B injector pump leak
TimMiller
Our case 480B has a leak at the injector pump. It appears to be coming out of where the throttle control linkage goes into the injector pump. Can you just remove this and replace an few o-rings, or do i need to remove the injector pump and send it off. Every time I park the tractor now I have to shut off the fuel or it will leak all of the fuel out of the tank (very slowly). When you park it you will see a puddle of diesel. It always starts right up though.
