The other day I was hauling gravel with my 730. I was in 4th on low side and went to shift into 1st when my shift lever stuck. I seemed to be in neutral but could not move shift lever. Hi-low lever works fine. I was able to tow it to the shop to be easier to work on.
Today I went to remove the shifter but couldn't get the deck off to I cut a spot to where I could get the shifter lever out. I still can't seem to get the shifting lever in position to where it will work. I took bar and was able to shift it into a gear. (thinking it was 3rd or 4th by the way the starter rocked the tractor. Visibility is very poor. Is there something out of line or did something break. Am I going to have to pull the top cover to find more out or am I not getting the shifting fork in correct spot??? It is dual range transmission and is a 68 model.
On another matter I see the trany oil is milky again. Would water be getting in around hi-low lever.
caseman-d
caseman-d
