I just bought a nice old 580CK (1969) and want to straighten out a cobbled together throttle linkage. I am waiting for a set of manuals so I am without a good reference for a while.
1. Wondering if you can tell me if the carb linkage rod from the front of the engine (pivot arm there with holes in both side) has any spring attached on the carb side of the tractor? My carb has no spring return for the throttle plate, either on the carb or the rod and I am sure it should have a spring to return the throttle plate and shaft back to idle when I let off the pedal.
2. The other side of the engine has a slider bar linkage that controls the pedal/rod and it is also rigged with bale wire between the end of the rod(front) and the same fixed front pivot. Seems to me the slider rod on that side should have a spring in there and perhaps an end linkage from the slide rod and the pivot?
Is there a handy drawing available showing the set up or can someone describe the two sides of the carb control linkage from that pivot point in the front to the carb and the other side from that frontpivot point to both sides? That slider linkage assembly on the right side (sittting on the tractor) has two 1/2 bolt head bolts that seem to allow adjustment by lengthening the slide but mine has nothing attached to that slotted piece?
I sure appreciate any insight you can offer. Thanks Ralph
