Silverdollar
New User
I recently purchased a Case 311 tractor. There are three chambers under and in front of the seat. The front chamber is where I add my hydraulic fluid that pumps out through a line into the back chamber. The middle chamber fills to the same level as the back chamber. In the middle chamber is the gears and is located under the stick shift. I drained all of the hydraulic fluid out and refilled to the proper levels according to the front and back dip sticks. The problem I am having is that after a while the back chamber fills and begins oozing out of the back chamber and the front chamber doesn't refill at all. It seems that there should be some sort of a relief valve that as the back chamber fills up it sends the excess back to the front chamber. I opened up the first and middle chamber when I drained the fluid, but didn't see anything that seem to be a return line or a dirty or clogged screen. Any suggestions?
