CC Case clutch problem
Farmallb
Just in case there hase been somebody new in here that may have an idea as to my clutch troubles, Im posting this again. My CC Clutch does not hold back when put in gear or operation. It falls forward after a short time or immeadiatly. I have adjusted it up to where it nearly takes all my strength to pull it back single handed, and brought it back to where a baby could pull it, and tried it at various places inbetween. No change. Whats your thoughts?? It is in Creek Co Okla
There must be wear on the end of the 3 fingers that run on the engaging "cone" that slides back and forth on the main input shaft. there is a very shallow recess right where the fingers should be at the front end of the cone for the ends of the fingers to settle into to hold it from disengaging. There should be a pronounced snap when the fingers drop into that recess, look it over carefully to make sure the fingers are getting to the recess to lock. mEl
