shellman14315
New User
Well today I was painting my 1974 580B backhoe and noticed I couldnt get the boom to lower. It would go up , but not down. Im referring to the portion that has two cylinders, one on each side. I looked at the cylinders and noticed there was some blue masking tape wedged between one of the cylinders and the seal. I must have missed it when I took it off earlier. I removed as much as I could, but some is still stuck inside. When the hoe is turned off, I manually hit the down button , but it still wont drop like usual. Im thinking maybe tape is now blocking the lines?
All the other hydraulics work fine and the fluid is topped off.
Could this be what is causing it not to go down? Is there a way to manually get it to go down, like loosening the lines to the cylinders. Im in need of some advice.
Thanks
Cory
Thanks
Cory
