I am currently having trouble with an 830. It has a spot where the engine will bind and not turn over, then I'll bump it with the starter to get it to roll over and then it will finally turn and with luck will start. I'm thinking maybe the rings are the culprit here, and are stuck in the lands. The engine does knock like heck when it does start and the knock varies as the RPM is increased and decreased. I thought a main brg or con rod brg could had been the trouble but the noise doesn't come from the bottom end.
Any info would be appreciated, thanks.
p.s. This is a great site.
T. Reavie
Langenburg, SK
T. Reavie
Langenburg, SK
