630 Case Wiring
jeepnjay
New User
Does anyone have a wiring diagram/schematic for an early Case 630 caseomatic. Looking to rewire starter and ignition.
Thanks
Jay
I checked that site and the diagram is not sufficient enough to wire up the starter switch and dash key switch.
Jay
I have the parts manual. Drop me an email and I can dump one out in adobe format. Let me know if you have high speed internet so that I don't overload your link. This is for the 500B-600B tractors which I believe are the square nosed starting in about 1958. There is one diagram of the instrument panel. Not sure if that is what you need or not.
Well I got the I&T manual for the 630 and the wiring diagram did not help. What I need to know is what shuts the diesel engine off? I have been usung the chocke but want to rewire a new ignition switch, not sure where all the wires lead, and which one shuts it off. Is there a fuel or air solenoid that I can look for????
Thanks
Jay
Disregard that post. I had a stupid moment!!!! After driving a diesel for years you would figure I would know that a diesel has no choke....
The cable is the manually actuated shut off. The owners manual was written for gas startup and shutdown and said to throttle down and turn switch off. The parts catalog showed 2 #'s for the choke cable and the other one was for diesel and was the shut off.
So thanks anyway!!!!!
Jayh
