CC Case Clutch adjustment problem update
Farmallb
Well, since I didnt get anything that would fix my problem with it falling out, Im gonna put a spring hooked to the bottom of the clutch handle and run to the nut that holds the emergency brake. Im going to hook a adjustable turnbuckle to the end of the spring so as to be able to add or take away tension depending on how she acts
