Have a 68 730CK with dual range transmission with dual loader. Loader has pump running off pto. I went to try the loader out by hauling a bucket of gravel. Once I started into the pile I had no response from the loader. Thought maybe the loder was low on oil but loader had no jerky motion , no nothing. I finally noticed that when ever I tried to raise the loader the pto would quit. Once the load was dumped it would raise the bucket enough to get to the shop.
I noticed that the oil was very milky and over full. Tonight I drained the oil. On bottom of tractor I found 3 plugs. The 1st one was just below the rear axle housing. That is the one I drained. I got about 17 gals of ugly stuff drained out. Ok what are the other 2 drain plugs, one just in front of brake drum and other one up by clutch housing??. Do I need to open these drain plugs also. Next, does the dual range have a hydraulic filter, if so where??I couldn't find one listed on caseih.com. Does the pto adjust the same as the older series Case tractors? Am hoping changing oil may help pto??
Yes I know I should get a manual but am unsure if I want to keep the tractor. I like the dual range shifting far better than that of the 700/800 series. Any help would be welcomed.
caseman-d
caseman-d
