clutch adjustment tool for Case DI
Just use a long punch. Push in pin -turn adjuster 1 notch at time till correct-than make sure locking pin is in notch.
Thank you so much for your insight and experience . I have just acquired a tool that will do just as you described.
My first reading of the adjustment proceedure was to raise the pin and not as you suggest depress the pin. This would seem a much easier endevor.
Thanks again.
I forgot direction you turn but check for easier or harder engagement at each segment as you turn . If it gets easier you are going wrong way. Should have a snap when you release. Probably know by now they run in engine oil. atahere is about a quart in cavity an you drain at bottom when you drain engine oil,It will fill its self.
