| Allis Chalmers Discussion Forum |
Topic: Allis Chalmers WD 45 Hyd Oil / Rear End
[Return to Forum]
| Author |
| Pete Churilla
03-25-2005 15:46:11
69.220.104.95
I am restoring a WD 45 and need to know what kind and weight oil to put in the transmission this also runs the hydraulic pump.Then I need to know what to put in the rear end.Do these two areas flow together? I know to use 90 weight in the cups in the bull gears. Appreciate any input.Pete |
| acorange
03-28-2005 07:10:16
216.248.102.129
Re: Allis Chalmers WD 45 Hyd Oil / Rear End in reply to Pete Churilla , 03-25-2005 15:46:11
| Use 85/140 in the trans. 80/90 will work but the trans. and hand clutch work better in my WD with 85/140. It may not matter with the spiral cut gears in the WD45. Just 10/30 oil in the hyd. res. works great or if you have any universal hyd. oil you can use that. The seal between the hyd. res. and trans. res. can leak between each other. If you are "loseing" hyd. oil and the trans. oil is "growing" this seal is out and the tractor has to be split to change it. This was not as much of a problem on the WD45's as it was on the early WD's. Just keep an eye on the fluid levels for awhile after you change the fluids. My 2 cents... |
| Guyzoo
03-28-2005 06:14:28
207.179.163.84
| If you can't find 85-140, 80-90 would be fine. |
| wdtom
03-26-2005 12:34:30
155.212.222.228
| The drain for the hydraulic is infront of the PTO. The fill is the little dipstick on the left side of the hydraulic husing. There are three drains for the transmission, The PTO, under the transmission, and under the rear end. There are two fills on the left side of the transmission/rear end, both plugs about half way up the side of the casting. Use all drains and fills to do a complete job of draining and filling. |
| bw in mo
03-25-2005 18:09:25
207.69.137.25
| The hyd pump is seperate from transmission, you will use hyd oil or a nondetergent 10 wt oil in the hyd pump. The hand clutch, transmission, rearend,and pto will use 85-140 wt oil. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
