'39 B rear rim to hub bracket question
Greenhorn
08-25-2000 05:56:45
I'm restoring the '39 "B". One rear rim appears to be original, one obviously isn't. The original one has 4 square brackets that are riveted to the rim and allow a bolt to pass through and connect to the hub. The non-original rim is the correct size but somebody cobbled something to it that needes to be removed. Are these square brackets something I can buy and weld to the rim? and if so, where do would I get them?
Thanks, Greenhorn
Dick L
08-25-2000 11:48:08
 Re: '39 B rear rim to hub bracket question in reply to Greenhorn, 08-25-2000 05:56:45
That in not orginal eather. I will try to get a picture for you.
