I have a few of these plows for my B's and have always fought with the plow using it at first. Plow is shined up real good yet it still has adjustments to get it properly set in the ground and with it not to deep or to shallow. I find that sweet spot after a bunch of runs up and back making a "mess". Is there a "starting point" that one could mount the plow so it would work fairly well with out much fussing to get it to run and then fine tune it that you might suggest? Also why are there mounting holes in two spots on the front hitch plates that mounts to the wheel axle? Which one is better to use or does it matter?
I know the plow for the B & C has had it's fair share of messages over the years (some by me) but maybe I missed this mounting setup. I read through the manual and it really doesn't say "use this hole and then this will happen" kind of thing. It's not like I have a bunch of land that needs turning so the adjustments just get working well and I'm done and for the life of me I never write them down.
